-   -   MAP Switch Failsafe Output (http://www.aquamist.co.uk/forum2/vbulletin/showthread.php?t=2971)
utc_pyro 12-10-2016 05:17 PM
Question about the orange map switch output of the ECU harness. I'm going to use it (along with the BCS failsafe) on a 32bit Subaru ECU to trigger the low IAM map via the test mode connectors.
When this output is "high", is the output current limited?
If not, is there a way to set it not to supply voltage when "high" but just pull the output down when triggered?
I still need to use the test mode connector for flashing, and I'm going to have an additional failsafe in the car tied to the same pin. I want to ensure it can be setup not to damage the HFS-3 if the orange wire is externally grounded.
Richard L 10-12-2016 08:36 AM
Re: MAP Switch Failsafe Output
The current is limited to ~8mA. You can invert this output using the FS1/FS0 jumper.
Alternatively you can use this output to switch on a NPN transistor to do exactly requested.
Remove the "CLP" jumper so you can connect it directly to the test-mode connector.
