-   -   HFS3 wiring ecu area (http://www.aquamist.co.uk/forum2/vbulletin/showthread.php?t=2990)
TTU666 16-12-2016 05:32 PM
Evening All
i am struggling a little here.
i have installed the kit on my rs4 b5 2000 model, me7 ecu.
i have done all the wiring and the kit is working fine, i am now on to the next stage of mapping it in. and my goal is to get a signal to my laptop for logging. i have been told to use the orange wire to the rear o2 lambda input for the signal. I have done this and it has not worked am i doing this correctly?
Also on the same harness i have no connect for the yellow wire or black wire, do they need connecting to for the Orange wire to work?
thanks
Richard L 16-12-2016 06:23 PM
Re: HFS3 wiring ecu area
What signal do you want to log?
Orange wire on the grey harness is a map switch wire.
TTU666 16-12-2016 07:41 PM
0 to 5v i have got it working if i put the jumper on fs0 but wont work on fs1
TTU666 16-12-2016 07:47 PM
My over all goal is to see it activate on logs for remote mapping for my file writer
Richard L 16-12-2016 08:21 PM
I am not sure what you are trying to do.
FS1 and FS0 only changes state upon failsafe activation.
TTU666 16-12-2016 08:27 PM
Rite OK I may be way off the mark here.
First of all where is the orange wire meant to go?
Secondly my main aim is to get a voltage signal from the grey harness into the ecu. So I can log when the meth is kicking in.I know I have the gauge but my file writer can't see this.
Thanks for your help.
