Control board not commanding FAV to open ... not true
Hello all,
I recently ordered an hfs4 kit from Jeff at howerton engineering. The kit was functioning perfectly for a few days but last week the kit stopped spraying. Jeff and I troubleshoot it down to the controller board. There are no clogs in the system. The FAV operates perfectly when supplied with 12v. The control board has no voltage across the FAV outputs when in SYS. The FAV wiring lead is continuous. There are no scorched connectors, traces of components. What do you guys think could be the issue? Jeff suggested I email aquamist about it but while I wait on a reply I figured I would lost here. |
Re: Control board not commanding FAV to open .
This is the correct place to have your aquamist problem diagnosed if you did not purchase your system from the aquamist-direct site.
Post a Hi-res picture of the top and bottom of the circuit board. |
My dealer told me to email you directly. Changing any of the jumpers or pots did. It resolve the issue.
http://imgur.com/m9LJIU3 http://imgur.com/1JIVPwz http://imgur.com/HFZNxpH |
In that case, can you tell me your first name so I can track down your email.
Daniel.
Thank you. |
Thank you. When did you email me last?
25 March.i will re-send it.
Got it now. Found it in the spam box. sorry.
I will get back to you after a careful look. |
Thanks so much. It been killing me, spending $1200 and not being able to use it.
Are you happy with the solution so far?
