-   -   My meth injection stoped working need help pls (http://www.aquamist.co.uk/forum2/vbulletin/showthread.php?t=3073)
Paulekas 05-06-2017 12:05 AM
Hi richard i have the old verion 1 basically today it stoped working completely so meth gauge is always showing full bars and if you trying to drive it it goes to limp mode on test mode mode it goes up and down in spraying testing mode it sprays is it dead completely or still there is something i could try? Here is pic car on idle car is not spraying just bars are all the way up also here is how my box is set its connected to the injectors
http://i818.photobucket.com/albums/z...psku4kctk5.jpg
http://i818.photobucket.com/albums/z...psvafilvno.jpg
Richard L 05-06-2017 07:41 AM
Re: My meth injection stoped working need help pls
As much as I like to help but there are no more replacement parts for this system, over 10 years old.
It appeared the flow sensor module (no longer available) has lost a ground wire, this will make the gauge display in full. Check the cable is not broken or shorted along the route to the engine bay.
Paulekas 06-06-2017 02:57 AM
Would newer version of flower sensor would work so i could buy it?
Richard L 06-06-2017 07:47 AM
The decoder is in the controller now, so it will not work.
I suspect the wiring. Can you measure the voltages of the four top pins on the right side.
Paulekas 06-06-2017 04:59 PM
I did continuity test from controller to both front sensors wires are fine also all good to the relay and motor in the back what else could i try?
Paulekas 06-06-2017 06:00 PM
I did meassure top 4 on right side so top 2 12vfs + and - are at 14v when car is running sensor v and c shows 2.9v
Richard L 06-06-2017 09:03 PM
This is a fault on the top two, it should read 0V.
Take a hi-res picture of the underside of the circuit board. I suspect there is a broken or burn out track. If this is the case, you can repair it quite easily.
