-   Gallery - NEW (http://www.aquamist.co.uk/forum2/vbulletin/forumdisplay.php?f=30)
-   -   1999 Audi A4 Supercharged - Aquamist (http://www.aquamist.co.uk/forum2/vbulletin/showthread.php?t=800)
franz@ktr 18-08-2005 02:38 AM
1999 Audi A4 2.8L V6 30v w/ PES supercharger
control box... holds FIA, priming pump signal extender, DDS2 junction block and fuse... status lights have been moved to the case so that they can still be seen for fault diagnostics...
http://www.ktrperformance.com/water_injection/30v1.jpg
Pump and related components have been moved to the previous battery location... we previously moved the battery to the trunk for better weight distribution... I made an aluminum plate that bolts into the factory mounting points for the battery tray...
http://www.ktrperformance.com/water_injection/30v2.jpg
Relay for race pump and pressure switch are located in ECU box...
http://www.ktrperformance.com/water_injection/30v5.jpg
LEDs for DDS2 display were added to the factory instrument cluster...
http://www.ktrperformance.com/water_injection/30v6.jpg
here is the box that holds the DDS2 electronics... usue a DB9 connector for all leads to the control box...
http://www.ktrperformance.com/water_injection/30v3.jpg
Rear water tank... (Not finished in this picture)
http://www.ktrperformance.com/water_injection/30v4.jpg
sorry about the poor descriptions, i've been forgetting to sleep the last few weeks.
