Old 03-12-2006, 08:55 PM
Default Methanol & lubricant
This topic was started over on NASIOC (Methanol without lube in it....) and I wanted to bring it over here as there seem to be many here using 100% methanol.
Have any of you experienced sediment build-up over time in the methanol with fuel system lubricant in it? I was originally going to order a 55 gallon drum of methanol with this lubricant in it to split with a few other locals who are running water/meth injection, but if it's going to develop sediment and particulates in it over time I may just go without the lubricant and add it separately after it's mixed in the fuel/water cell.
Anyone have any additional input on this?
Old 03-12-2006, 09:19 PM
sdminus sdminus is offline
I cant see how you will be able to keep oil suspended in methanol. I would presume it will seperate. It will be differant to water which will mix 100 % with water in any amount
Scott
RX7
Old 05-12-2006, 08:53 PM
That seems to be the conclusion that many are coming to. If the methanol w/lubricant is left dormant for any extended amount of time the lubricant starts to fall out of suspension.
Looks like pure methanol may be the way to go.
Old 05-12-2006, 09:00 PM
You could use some kind of RC car or plane fuel
http://www.modeltechnics.com/
RX7
