Old 06-07-2009, 01:37 AM
Dust Dust is offline
Default Mix is draining, will a solenoid help?
I have a pre-turbo and post turbo nozzle set up, with the check valve before the T. The pre-turbo nozzle is the lowest point in the system, and it seems that the mix is draining into the preturbo nozzle.
If I get into boost and then have to slow down, my car stumbles and will sometimes die. This tells me that I am draining or that the mix I am spraying is too much for the pre-turbo location.
What I was thinking about is moving the check valve to the upper post turbo nozzle, and mounting a solenoid at the pre-turbo nozzle
Old 07-07-2009, 09:32 PM
raddy raddy is offline
http://www.aquamist.co.uk/phpBB2/viewtopic.php?t=1286
