Old 13-03-2010, 08:28 AM
flyinryanp flyinryanp is offline
Default fail safe for centrifugal supercharger
what would be the best way to lower boost pressure with a centrifugal supercharger.
Old 13-03-2010, 08:36 PM
Howerton Engineering
Default Re: fail safe for centrifugal supercharger
Do you have a BOV or Bypass Valve? Can you elaborate more on the setup so we can get an idea of the hardware/software capabilities and limitations, then we can put forth some options.
Old 23-03-2010, 10:24 PM
07 corvette zo6 with an a&a supercharger kit. its intercooled and has a b.o.v. you can see all the setup on the a and a website. also can you put the meth nozzle after the throttle body butterfly
Old 24-03-2010, 03:02 AM
It might be an abrupt power loss, but you could activate the BOV in a failsafe event. Not sure what it dumps boost to, maybe all the way to atm., but it would certainly protect the engine.
You could use a secondary BOV with smaller orifice, or any valve for that matter to limit the amount of boost dumped leaving the primary BOV to operate normally. It would be a bit of trial and error process, but could be a smoother operating system.
Old 25-03-2010, 08:06 AM
found an air solenoid for air ride that will vent boost should be easy to hook up what about putting the jet after the throttle body plate.
Old 26-03-2010, 01:33 AM
You can put it after, but the farther away from the intake manifold usually the better. It allows a longer time for mixing, and evaporation. This gives the best mixing and homogeneous mixture, thus promoting the best distribution throughout the manifold.
Old 26-03-2010, 02:05 AM
i would like to put it further away but the maf sensor is right at the throtlle body
Old 26-03-2010, 03:04 AM
So forgive my ignorance on this. Looking at the Z06 intake, is there a center plenum, starting at the TB, that goes the length of the manifold that the 8 runners draw from? I'm trying to get a feel for the layout of the intake design and runner entrances, etc.
Old 26-03-2010, 07:42 AM
does this help
Old 26-03-2010, 03:41 PM
After the TB, is there a log down the middle of the intake manifold that the 8 runners draw from? How do the 8 runners I see on top draw from a plenum?
