Old 06-06-2011, 02:42 PM
lucifer lucifer is offline
Default MK4 Golf R32 turbo
Hi. I have a MK4 Golf R32 that has had a HPA blackjack turbo conversion done to it. The car is now making 500 bhp and 475 lb torque. Can you please tell me which of your kits would be best suited to my car and what nozzle sizes i need so i can add water/methanol injection to the car so as to squeeze some more power from it safely. Thank you.
Old 09-06-2011, 03:26 PM
Default Re: MK4 Golf R32 turbo
An answer would be helpful please.
Old 09-06-2011, 05:55 PM
FlyingGrape FlyingGrape is offline
You have posted in a general area. If you are after info on aquamist products then recommend you post in that section and Richard Lamb of aquamist is more likely to see it.
Presume you are looking post turbo rather than pre turbo.
For sizing there is a lot of info on the site about this. Firstly you need to look what mix you wish to use. Water only, 50/50 water meth, or some other mix in between as this will determine the injection amounts, around 10-15% for water, 15-20% for 50/50. Final amount depends on engine setup.
Jet sizing is also based on injector sizes and number of injectors which you have not listed.
Try here
http://howertonengineering.com/tech-...ating-jetting/
Choice of products is also about the level of control you want. All aquamist kits are great (yes I have one), especially in area of failsafes. I would suggest looking at HFS3.
Old 10-06-2011, 05:51 PM
Thank you for your helpful reply. Sorry for posting in the wrong section. Please feel free to delete this thread if you wish.
