I can't seem to find any info on what the stock injectors put out on this engine. Anyone have any idea what size jets to run for a direct port application (6 jets)?
I have an hfs6 that i will be using. Hate to buy 6 valved jets @ ~$55ea and be the wrong ones. Will be pusing about 13-15psi. 50/50 meth Thanks! |
After finding out more info on the tfsi engine, is it even possible to use an aquamist system since there really isn't a set idc?
Yes, we have setup many kits for the TFSI. Roughly you can say 1.5 x the HP for jetting, or for a 300hp engine, 450cc.
![]() Quote:
Will the hfs6 work for the DI engine? Or do I need a hfs4 for this car? |
The HFS-6 is not setup to work with this injector setup. In the past it was modified to work, but the new systems do it much better. The 6 was discontinued a few years ago and other than spare parts supplies, is not supported in that manner.
