Old 09-08-2017, 08:11 AM
denis1282 denis1282 is offline
Default Wiring diagram for opel (Vauxhall) astra j A14NET
Hello.
Thank you for your great product, but I encountered some problems during the settings and now I no longer have confidence in the fact that I did the right connection (that I have correct wiring connections).
Please help me find answers to the following questions:
1) Do you have wiring diagram for opel astra j (motor type A14NET)?
2) Where are should be connected white, brown and black wires located in the grey harness?
3) Fail-safe goes into "safe mode" too early and does not allow to configure boost pressrure more than 0.6 bar
Thank you in advance for your support.
Old 09-08-2017, 08:46 AM
Default Re: Wiring diagram for opel (Vauxhall) astra j A14NET
1) I don't have the wiring diagram for this car. I can make one if you send me the factory ECU pinout diagram.
2) Cut the wiring between the ECU and BCV. Connect the white to the ECU side and Brown to the BCV side.
3) Trigger the system via the IDC rather via MPS. Or lower the WL trimmer (C-CW).
Old 09-08-2017, 09:27 AM
Thank you Richard.
What about black wire which is located in the grey harness? is it should be free (disconnected)?
Old 09-08-2017, 11:14 PM
yes, not used.
Old 16-08-2017, 11:58 AM
Hi Richard,
please see factory ECU pin out diagram by link below http://fayloobmennik.cloud/7072674
I have direct injection engine.
BR, Denis
Old 16-08-2017, 12:14 PM
If first link will be incorrect, please use the second one https://drive.google.com/file/d/0B3k...ew?usp=sharing
BR, Denis
Old 20-08-2017, 07:08 AM
Got them. Nice neat translation, thank you. According to the diagram, the engine is not direct injected. Please confirm.
Can you post a photo of the pin out side of the ECU with the connectors removed. I cannot make a drawing until I get this.
Old 20-08-2017, 07:22 AM
Originally Posted by denis1282 View Post
Hello.
Answers:
1) No. Not yet
2) Cut wire from pin #30 of K20. Splice in the white wire (ECU side) and brown wire to the Solenoid side. Black is not used.
3) Adjust WL counter-clockwise a few clicks.
What is the maximum Fuel injector IDC%?
Old 30-08-2017, 06:46 AM
Hi Richard,
please see the pictures below
And yes, you are right, I have a distribution system for injection, not direct injection
Regarding IDC, I still use original mode
