Old 04-06-2018, 04:59 PM
tezlum tezlum is offline
Default Water Level light
I have had my Hfs 3 working flawless for a few months but one dat I noticed I wasn't getting full boost then looked at the aquamist gauge water level light was on. I think fill the tank full now any time the aquamist activates the water light turns on and activates the failsafe but the water injection light doesn't turn on like it was hitting a failsafe. If anyone has had this issue any input would be appreciated I will pull the bumper off soon and look at the level sensor and connection
Old 06-06-2018, 01:15 AM
Default Re: Water Level light
I have tried today turning the WL CW a few clicks and I get a failsafe activated. Then I turn it back (CCW) 2 no Water Injection Light but the Water Level light comes on and the tank is full. Tried full CCW and the Water Level light still comes on with initial injection and goes way after the failsafe is reset.
Old 08-06-2018, 01:42 AM
I have tried today disconnecting the water level sensor and still does the same thing where the water level light comes on without the water injection light coming on and going into a failsafe. I reset up SC and WH and WL and still I get a water level light on initial boost and it stays on till it stops injecting. The light is not flashing like as if I was out of water
Old 08-06-2018, 08:21 AM
where is the pump located?
Old 08-06-2018, 08:25 AM
I have the pump located in my front bumper/ fender behind my fog light away from the rad and exhaust
Old 08-06-2018, 08:32 AM
There is a chance the pump is seized. It should never be mounted in the engine bay.
Old 08-06-2018, 08:44 AM
I do have in a compartment that see no water and very minimal heat no more than inside the car, is there a diffinative way of testing if the pump is the issue because I pulled the jets earlier and I got a good spray pattern
Old 11-06-2018, 07:14 AM
I had taken my pump apart and found it was slightly corroded on a few screws and the walls would still be enough to cause an issue like just the water light coming on
Old 11-06-2018, 08:16 AM
you are looking at the wring end. Open up the pump head.
Old 11-06-2018, 07:52 PM
you are looking at the wrong end. Open up the pump head.
I got that part of the pump apart looked like not much water intrusion there. All the bearings spin freely, But if you think I need a new pump I'll order one as I'm going to get your dual tank set up so I can move it into the trunk so I don't damage anything further.
