I drive a MKIV Supra TT, I havea system 1s fitted which is preset to come on at 10psi. My car runs a maximum of 1.2bar (19PSI) Should I change the Boost Pressure switch so the water injection comes on closer to max boost. If so what would you recommend, about 14psi? Is running the water injection at 10psi a waste of time?
Cheers Vaughany
On the 8th Day, God created Supras |
