Old 06-04-2005, 03:55 PM
CosRush CosRush is offline
Default General Advice as to whether WI is the way to go...????
Can you use anything like a high pressure Shurflo water pump for WI???
Any thoughts or comments on this???
Cheers
Old 06-04-2005, 05:15 PM
Yes, an ideal pump to start, theyhave a great range and the cost is very reasonable. Mnay poeople make their own system with it with good results.
Old 06-04-2005, 07:54 PM
Pressure wise, is the cheapest option to buy the 100+psi pumps or can you upgrade a lower pressure one???
any idea?
Old 06-04-2005, 11:13 PM
I will go for a 100psi one. it will be a downgrade to go for a lower psi one.
