Old 08-10-2005, 11:36 AM
miata_rp miata_rp is offline
Default Flammability of Methanol/Water Mixtures
Hello to Everyone,
I am new to the use of water injection in my car. I was a bit concerned
about mixing methanol and water as I read in an industrial brochure that
a 33%methanol to 67% water mixture by volume is the absolute maximum
mixture to keep it non-flammable.
Is a 50%methanol/water mix flammable? Even if it is stored in a plastic washer container in the engine bay, I'dlike to play it safe.
Thanks!
Old 08-10-2005, 11:44 AM
chucktoo chucktoo is offline
Default Flamability
My kitchen chemistry experiance is the same -1/3 -2/3 H2O I cold not get to light.
The typical 1/2 - 1/2 does light but does not burn very well.
Old 08-10-2005, 05:06 PM
JohnA JohnA is offline
In my experience the 'methanol' effect tails off after just 20%, let alone 33% meth/water.
So I don't see much point going beyond 30% anyway.
In practice I've settled down to 15-20% and it works well. :smile:
John
www.max-boost.co.uk
Old 09-10-2005, 01:22 AM
Thanks for the replies. I'll stick with the 25% meth to water ratio. I was just curious why a lot of references are around with regards to the 50/50 mix
