Old 12-02-2006, 09:22 PM
DJ DJ is offline
Default Injector Amplifier (FIA) question
HI Guys
I installed a 2D kit on a toyota supra (800WHP), I kept in simple with a high flow water pump/shurflo and the FIA and two 1.0mm nozzles on the Interncooler piping.
I have an AEM engine managment system, resistor solenoid inline the injectors. Peak and Hold type 800 CC ones.
What`s the pressure switch rated at from factory?
How many miliseconds should the FIA reads before actual injecting water in the system?
I haven`t put it on the dyno with hogh boost, high IOT ms, but on neutral, and rev it to 5-6000 rpms, by passing the pressure switch I can see the red led on Fia pulsing but no water going trough nozzles, of course it might be around 1,5 to 2,5 IOT ms, so I though it wasn`t enough to see water coming out
Thanks for the comments
DJ
Caracas, Venezuela
Old 14-02-2006, 03:39 AM
DJ DJ is offline
The pressure switch is factory rated at 10 psi
Clockwise will yield a higher psi rating Counter clock wise will do brackwards a quarter turn will yeild 2 psi aprox difference
System works great with a 12V switched as for injector in the supra
Old 14-02-2006, 11:35 AM
Default Re: Injector Amplifier (FIA) question
Hello DJ,
The FIA2 can read pulses down to 2.5ohm injectors (peak and hold mode) but if you are using 1.2ohm injectors, we need to modify the FIA2 to read it.
I think your present problem is due to the FIA2 only seeing the "peak" portion of the pulse (about 1ms) and not seeing the "hold" portion. Please email me your address and I will send to a modified FIA2 to replace you present one.
Originally Posted by DJ
HI Guys
DJ
Caracas, Venezuela
Old 14-02-2006, 01:55 PM
DJ DJ is offline
Hey Richard
Always amazing me with your service mate, the system is working GREAT! Terrific with standard aftermarket supra injectors, siemmes type, top feed!!
This is in the 2jzgte with AEM EMS
Thanks I will post my dyno results soon
DJ
Old 14-02-2006, 07:38 PM
I look forward to your results.
Hey Richard
DJ
