Old 19-05-2016, 01:40 PM
porterhouse07 porterhouse07 is offline
Default HFS4v3 on 2013 Mazdaspeed3
I have a HFS4 kit about to be installed on my genpu soon. I've seen the wiring diagram for the HFS4v2 kit. Is it the same for the v3 kit?
Also, at the bottom of the diagram it shows what do at the solder locations. I should change the setting for the MAP sensor because I have a 3bar MAP, correct?
Is that all that I need to change and I'll be good to go?
2013 MS3 Black Mica
GT3071R | HTP 3" Intake | Magnaflow CBE | Grimmspeed EBCS | Bosch 3 Bar MAP | AP v3
CS HPFP Internals | CS Catted DP | CS RMM | TR8L FMIC w/ JBR Piping
HKS SSQV4 BPV | CS SSP | Swift Springs | DM Stage 3 OCC and PCV Plate | EBC Slotted Rotors w/ Yellowstuff Pads | NGK Iridium -1
Freektuned 350/365 @22psi
Waiting to install.... TR8L Core/Aquamist HFS4/NGK -1 Plugs
Old 19-05-2016, 05:24 PM
Default Re: HFS4v3 on 2013 Mazdaspeed3
It is the same.
Post a picture of the controller topside.
Old 19-05-2016, 05:30 PM
I will as soon as it arrives. I'm still awaiting it's delivery
2013 MS3 Black Mica
Old 20-06-2016, 03:02 PM
It is the same.
Finally received my kit. Haven't had a chance to get the picture of the board but I will tonight.
What size Posi-Tap/Posi-Lock connectors are needed for connecting the harnesses to the ECU?
2013 MS3 Black Mica
Old 21-06-2016, 12:06 AM
Here is a photo of the board. It seems as though it's defaulted to 3.5bar MAP so all I should have to do is adjust the jumpers for 2.5x and I'll be set.
File Type: jpg image.jpg (157 Bytes, 31 views)
2013 MS3 Black Mica
Old 26-06-2016, 08:52 PM
It is the same.
I'm not sure why my picture didn't attach to my last post. But I Have the image attached again below. It does seem as though it is configured for a 3.5bar MAP sensor so I'll I should have to do is rearrange the jumpers for the x2.5scaler correct?
I also bought your tank as was trying to figure out how this thing is supposed to mount in my car if I mount the pump to the bottom of the bracket. I don't see any other mounting points except for the ones to mount the pump.
Thanks for your help.
2013 MS3 Black Mica
