Old 12-10-2017, 01:23 PM
UCTURBO UCTURBO is offline
Default Direct port nozzles
When choosing the aquamist DP nozzles, do you subtract boost pressure and the 1bar cracking pressure from the flow in the graph or just boost pressure? Cheers
Old 22-10-2017, 07:11 AM
Default Re: Direct port nozzles
Correction, you only subtract turbo pressure only. The DP jet flows are calibrated with CV inserted.
