Hi i'm new to this W/I stuff and was wondering what size injector i would need to run? i own a 1995 supra twin turbo mod's: MINES ECU CHIP, HKS S40I SPARKS PLUGS, WALBRO 255ltr/Hr FUEL PUMP, DECAT PIPES, K&N AIR FILTER, FMIC. Running about 335rwhp @1.1bar, i have got a boost controller to finsh putting which will be running @1.2bar on standard turbo's.
It depends what mixture you are running (pure water?), I`d start off with 10% of your peak fuel flow rate personally on water.
If you`re running water/methanol then that changes things a bit.
don't really know what to run what would be the best?
