HI all
I need to get a kit for my Audi TT. Im reading on here like mad, but any help would be great. 2.0 Lump 4x 750cc injectors GTX30R76 4" Inlet Pro Alloy FMIC with Large pipe work (80mm) Standalone Managment 600 ish BHP I hope for. Should I just run a single nosel after FMIC. I read that the only point in putting one before blower is if removing FMIC which I certainly wont be doing. Any help or advice would be great. Cheers Sheldon |
http://howertonengineering.com/tech-...ating-jetting/
The examples on the page are older then the graph, just use the formula and chart and you will find your jet size. The reason to run two jets is if your target water and or meth cc's are more then 1 jet can deliver you divide the # by two and run two jets that size. |
