Old 29-08-2013, 02:09 AM
jturnbull jturnbull is offline
Default Failsafe Kicking in
I'm having an issue with my HFS-3 where around 5500 rpm the failsafe is kicking in and disabling high boost as it should. I can't seem to figure out what the issue is. I have purged all the lines, cleaned the jets and FAV. It starts flow at 4000 rpm and gets 4 or 5 bars then cuts out at 5500 rpm.
The car is 01 S4 with high impedance Bosch EV14 injectors.
When I first installed the kit on my base tune I did not have any issue, held 4-5 bars of flow to redline. Went for a tune and we were not able to tune for the Aquamist as the failsafe started kicking in. The tuner has tuned 300-400 aquamist cars with no issue like this before. Tuner said he thought it could possibly be a bad FAV?
Old 29-08-2013, 02:33 AM
Default Re: Failsafe Kicking in
Only change before the tune was the switch from 100% distilled water to 50/50 water/methanol which came out of a sealed 5 gallon container.
Old 29-08-2013, 04:41 PM
Does the gauge showed a drop in delivery rate at 5000rpm?
Old 29-08-2013, 04:57 PM
No. Flow is consistent between 4000-5500rpm at 5-6 bars.
Old 29-08-2013, 06:47 PM
move WH a couple of clicks clockwise and let me know. 50:50 have a slightly different viscosity than 100% water.
Old 29-08-2013, 07:06 PM
When my tuner was doing the tune he tried setting WH fully clockwise and WL fully counter clockwise and we got the same results.
Old 29-08-2013, 08:57 PM
So changing from 100% water to 50/50 caused the failsafe to activate?
Where is the "FS-DL" set to? (controller)
Old 29-08-2013, 09:08 PM
Right before I went for a tune I filled the tank with 50/50. I never really went into boost on the way to the shop so I cannot say whether or not that was the case. However he was able to fine tune my base map with out any issue.
I read through this http://www.aquamist.co.uk/vbulletin/...ead.php?t=2091 thread and it seems like it could be a threshold issue?
When he started to turn up the boost and dial in the tune for the methanol thats when the failsafe started to kick in.
I tried adjusting the FS-DL fully clockwise last night with no change.
Old 29-08-2013, 09:12 PM
it does not make sense if none of the trimmers have any effect.
What is the "threshold" setting now?
Old 29-08-2013, 11:53 PM
No matter where I adjust the threshold it will just kick in later but continue to cut the boost around 5500 rpm.
I have:
WH fully clockwise
WL fully counterclockwise
FS-DL fully counter clockwise
