Old 30-11-2013, 05:45 PM
bulldogface bulldogface is offline
Default HFS-3 troubleshooting
Hi, is there any troubleshooting guide for hfs3 v3 to point me to? My problem is that as of recent, my kit fails to work properly, so always, when i depress pedal, baragrapf won't read anything, just failsafe kicks in. i checked all wires 3 times around, so seems like now is the time to do diagnostic via jumpers on circuit board..however i have no idea what results i am supposed to get.
Old 01-12-2013, 05:20 PM
Default Re: HFS-3 troubleshooting
The system is telling you there are flow problems.
Try the following first:
1. Check for clogged nozzle. unplug it and do a manual test.
2. Prime the system (read manual).
3. If all is well, bridge the "SYS" link again to activate the system. One minute at a time. It will switch the pump on and the FAV at 100%. With the jet taken off. look for the spray pattern.
Old 04-12-2013, 04:06 PM
Yo, sorry for so long delay, but i tried to "try all possibilities" before spaming again. However, even after purging the system, it still fails to work properly. Upshot is, my bargraph never reads anything. even while manually purging, instead it just lights both leds. Durring drive test, i get blip of "B" along with sound of pump kicking in, and than failsafe kicks in. is there any contact on for ex. flow sensor, which is prone to fail if, dunno, is freezing, dirty, too near to source of heat, or christmass too near?
Old 04-12-2013, 06:40 PM
Please snap a few pictures of the FAV location.
Question... Does the "S" symbol stay lit at all time?
Old 04-12-2013, 09:52 PM
Old 04-12-2013, 09:57 PM
yes, it does.
Old 04-12-2013, 10:06 PM
It looks the FAV and flow sensor is being cooked by the turbo below. The user mention to put the FAV on a cooler dry place. You have picked the hottest place possible. Please relocate if it is not already too late.
Old 04-12-2013, 10:18 PM
It is probably going to be, since it won't operate even with cold engine and hood open, with ambient temperature bellow 0. So is there any way, how to check which component is gone?
Old 04-12-2013, 11:44 PM
undo the outlet of the FAV:
Do a manual test by linking "SYS" jumper. If they are plenty of fluid shooting out of the FAV, the FAV is fine.
At the same time, see if there is any bar display on the gauge. If not, it most probably be the hall effect device in the yellow sensor cable. You can send the cabel back to me for testing.
Lastly. undo the sensor tube from the FAV, blow through it and tell me if you can hear a whirling sound. If you can, the turbine inside the sensor is OK. Just need to replace the sensor cable.
The hall effect device does not like heat at all.
Old 05-12-2013, 03:18 PM
Hi, I looked at it today, and it seems like FAV is ok, and from sensor valve i can hear faint whirling sound. So hall effect it is, aparently. As a word of experience for anyone, who'll wonder in a future, turbo heat shield is NOT sufficient protection against heat. Thanks for help, Richard.
