Old 30-06-2017, 01:59 AM
Redline99 Redline99 is offline
Default Hfs3 wiring to vipec v88 and jet for jdm supra 97
Hello,
Currently installing this kit on my 97 jdm supra rz 6spd tt, is the jdm supra harness different than the usdm harness pinout? As I'm finding it tricky to find a jdm wiring schematic, I'm running the Vipec V88.
Could someone possibly help me out and inform me on which pins to tap into for the ecu wires required?
- Inj. (+) or ign. Pre crank
- Inj. (-)
- map sensor
- assuming I won't require the auxillary wired in?
Also, reccomendation on jet size? I have 1000cc Injectors, bw366, will be looking to run 25psi +.
Any help is greatly appreciated!! Thankyou
Old 02-07-2017, 12:22 PM
Default Re: Hfs3 wiring to vipec v88 and jet for jdm supra 97
No other wires are needed.
