Old 24-08-2005, 11:17 PM
Greenv8s Greenv8s is offline
Default water injection *causing* detonation?
It's a crazy idea, but bear with me.
I'm running a low boost supercharger (0.4 bar) with a relatively long inlet manifold, probably five feet or so total length. On boost I run upstream water injection, just a 0.7mm jet connected straight to the pump.
With the water off I get slight detonation on boost, by 'slight' I mean that there's a quiet rattling noise in the background but no really heavy bangs. With the water enabled it seems to pull better, the background rattling noises seem to stop but sometimes I still get very loud detonation.
I'm wondering whether the water injection might be causing this in some way, and I've got a theory that explain how it might.
According to this theory, it is very important how much of the injected water evaporates upstream of the intake valve. Water that evaporates upstream cools the charge and enables me to get more charge into the cylinder. Water that evaporates downstream of the valve cools the flame front during the combustion process and suppresses detonation. According to this theory, cooling that occurs upstream might actually be promoting detonation by increasing density (and hence peak temperature and pressure) in the chamber. Hopefully the amount of water that gets into the cylinder before it evaporates will be more than enough to offset this, but I don't see anything fundamental to ensure that it will be.
What do you reckon, am I barking up the wrong tree?
Old 25-08-2005, 01:41 PM
rgathright rgathright is offline
You could also not be getting an even dispersal of the water/air stream.
By this I mean the intake ports closest to the TB / Intake get the majority of the flow and the banks furthur away are still heated. The problem with water cooling is it still does not address the heat in the intake manifold. Water/air cooling can only address the heat of the incoming air.
To prove this, put a thermal probe on your intake manifold at different points. If you have a temperature shift greater than 30F from one point to another you may need to address the problem somehow. IE: 160F at the rear of the intake and 190F at the front.
Here is a link to the thermal probes I use. At $20 it is a real bargain. I leave mine installed in the engine bay. http://www.directron.com/driverrack.html Yeah it's designed for PC's, but I have had no problems.
Old 26-08-2005, 05:18 AM
Your theory has some basis, by spraying before the supercharger you increase the effeciency and massflow through the supercharged ---- in effect your raising the boost.
I think you may want to look at a method to add a post supercharger spray to control the detonation and leave the pre-supercharger spray to increase the effeciency of the blower.
Old 26-08-2005, 01:36 PM
dsmtuned dsmtuned is offline
Default Re: water injection *causing* detonation?
Are you only spraying with only water? I have tried water, a mixture of isopropyl alcohol (which lead to more knock), and a mixture of methanol and water. The latter has worked the best to provide good cooling and knock suppression.
-Craig
Old 27-08-2005, 01:16 PM
-Craig
For competition use I'm only allowed to run plain water and pump fuel.
