Old 15-12-2006, 03:52 PM
ace_on_17 ace_on_17 is offline
Default Location of the nozzle for caldina GT4 (3sgte)
Hai guys! im new here..
I just bought Aquamist System 1s for my Caldina GT-Four (ST246) version..My question is, where should i place the nozzle? is it between the throttle and the IC or between the IC and the Turbo?
My problem is that both the throttle body and the turbo are very close to the intercooler...so im hoping for some advise and suggestion of where should be the best place i put the nozzle and how should i do it...
Old 16-12-2006, 09:30 AM
On your car, most of our users put the water jet in front of the intercooler whicj helps combating the heat soaked inetercooler.
Old 16-12-2006, 04:52 PM
Hai Richard L..Thanks for your replied..anyway,what do you mean by in front of the intercooler? is it after the turbo or before the throttle body? or do you mean at the top surface of the intercooler ( act like the intercooler water spry?!)
btw,where should i connect the switch wire (purple wire)?
Old 16-12-2006, 10:27 PM
I mean to put the jet between the turbo and the IC.
The Purple switch wire should go to any switched 12V supply. Ignition key?
Old 17-12-2006, 08:49 AM
what do you mean by "ignition key?" hehe i just confuse :lol: ...
Old 17-12-2006, 12:00 PM
Ignition key normally switches most thing on. If I say innition switch, would it make better sense?
Basically, you need to connect the purple wire to a location where there is a 12v present upon turning the ignition key.
Old 17-12-2006, 02:16 PM
yap..thanks mate..i got it...now,this is my problem...My IC are very close to the turbo..as you can see from the pic..so,should i make a hole on the rubber (for the nozzle)joining the IC and the Turbo?..it seem like there are no space in between..
Old 09-06-2007, 01:03 PM
Can you tap a hole on the inlet (end tank) of the IC?
Old 06-04-2008, 12:41 PM
Dust Dust is offline
Do you know of any websites for caldinas?
