Old 26-01-2010, 09:06 AM
EngineerX EngineerX is offline
1. How do we order the tanks to get the discounted price?
2. Will shipping cost be combined with the HFS-3 ?
3. Are the remote fillers also discounted? What price would they be sold for?
4. Do the the remote fillers include the hose to link with the tank? How do they interface with the tanks you sell?
Old 26-01-2010, 04:47 PM
Howerton Engineering
Just let us know what you want with the HFS-3 so we can allocate it in stock. When the GB closes Richard will get deposits from everyone for the kits. The GB list then gets forwarded to us. Once the kits arrive, we will contact everyone for final payment and you can pay for your tank at the same time.
After the GB ends, the GB participants can still add tank items up to the time we ship, but obviously we would like to know sooner rather than later what needs to be ready.
The shipping for the kit is a fixed price, if any items are added additional shipping will apply. Please contact us with your needs so we can get you a shipping quote.
Remote fillers are $20 normally, 20% off or $16 for the GB. This price is only for the remote filler, most of these get sold to tuners who are doing custom installs. If needed we can investigate supplying the hose and barb fitting for the tank if needed.
Old 26-01-2010, 07:05 PM
Thanks for the prompt replies.
The 1.5G tank looks great for an in-trunk setup.
I noticed the tank's outlet to the pump is right on the "trough" of the tank, on the base where the pump mounts.
That seems to be about 1.5 inches above the bottom of the tank. So when the height of the pump's inlet is added, that's about 2.5 to 3 inches above the base of the tank itself.
My question is,
Is that base under the pump's mounting location full of liquid?
Can the pump "suck" and prime liquid once the tank level falls below the height of the pump's inlet? (it's a considerable volume, the whole 12"x8.5"x1.5" base + another ~1.5" "U" shape volume.
Also, is the tank outlet fitting flush on the base, or does it have a tube pick-up / siphon to allow pump to suck liquid when level falls below the pump mount base?
In your experience, down to what level (inches from the bottom of tank) is the tank's capacity usable when the pump is mounted in the trough and the tank's outlet is used?
Tanks!
Old 26-01-2010, 07:31 PM
The base of the tank is full of liquid. The fitting that is screwed into the tank has a suction tube extending to near bottom of the tank. There is no issue priming at these small height differences, as long as there are no breaks or leaks in the line/fittings going to the pump breaking the suction.
The theory behind the design is good, but this tank does suffer from surging issues when below half full. A simple solution to mitigate a good deal of this is to mount the tank at a slight angle(not level). This will keep the fluid from rolling away from the siphon tube too much. I have one customer that used a "whip", frequently seen in the karting world, that has a brass pick-up at the end of a flexible line and this brass unit moved with the fluid staying submerged and preventing the pickup of air. The best advice I can give with this tank is to try to keep it over half full if at all possible and mount it at an angle slightly towards the pickup. I'm not trying to talk you out of the tank, I just want to be honest about our experiences with it.
Pleas note we bought a batch of these long ago just offer as another tank option for our customers. Therefore we have not had any input into the design or overall presentation of the product. I can't say it's always the best tank for the job, but does fill a niche and fit well for certain applications. When the few that we have left are gone we will not carry them any longer as we expect to have our own product design ready to offer in the next 6-12 months.
Old 02-02-2010, 12:57 AM
gengo gengo is offline
Is a vented cap enough to ensure smooth fluid delivery? Would a vent line be better?
Old 02-02-2010, 01:18 AM
The cap and the line will do the same thing for air flow purposes, we usually use a vented line if folks are using 100% meth and the vented fumes need to be to the outside of the car.
Old 04-02-2010, 11:30 PM
If a tank is ordered pre-drilled, does that mean the fittings come installed too?
If not, how are the fittings installed? Some kind of silicone/sealant?
Thanks.
Old 04-02-2010, 11:42 PM
If you are getting a bare plastic tank, mark up the drawing on the site where you want the fittings and we will install them and soak it overnight before shipping.
Otherwise the fittings in the kit are just a rubber compression type, you drill the hole, deburr, and insert and tighten.
Old 13-02-2010, 06:25 PM
PROJEK X PROJEK X is offline
I am 110% happy and completely satisfied with the quality and workmanship of the Twin Tank Set-up. And i think i had one of the 1st set-ups available, if not the 1st
TeeJay (OverBoostinBimmers)
Einy, Meany, Mieny, MO:
08 Mitsubishi Evolution X GSR
08 BMW E90 335i
09 BMW E82 135i
Old 24-02-2010, 05:27 PM
jajou jajou is offline
Can't wait to get my kit.
Jeff keep up the great work.
-Tony
