I have an Audi S4 and I wired it up as I told through my tuner and I am getting power to the 4 pin connector but no power to gauge. The only wires that arent hooked up in the ECU harness is the orange, yellow and black wires. This is how I was instructed to hook it up:
HFS3 Red - Injector Power - Thick BLUE/BLK wire (or BLACK/BLUE), Check at any injector HFS3 Green - Injector Duty - BROWN/GRN (I believe this is the only injector wire that isn't the same color as something else), Check at INJ #4 (DS Front) HFS3 Blue - MAP - BLUE/GRAY - Check at MAP Sensor For the failsafe: BLUE/GREEN - N75 Signal - Check at N75 -CUT THIS WIRE- HFS3 White - The ECU side of the CUT BLUE/GREEN wire HFS3 Brown - N75 side of the CUT BLUE/GREEN wire. HFS3 PINK, YELLOW, BLACK - UNUSED ________________________________________ ___________ The 4 pin connector gets wired at the fuse block under the dash 4PIN RED - Keyed Power - First terminal towards the door "75X" 4PIN WHITE & BLACK - Grounds - There are two factory ground points directly above the kick panel near the hood latch. You can connect these two together there. 4PIN - PURPLE - Dimmer - I don't hook this up but if you wanted to its somewhere in the headlight switch harness |
Can you check test point 5 for me -Injector (+). Should be a 12V there when ignition switch is at the pre-crank position. Unplug the blue harness for the time being to stop the water level sensor interfering with the start-up procedure.
Ok, problem fixed and I am now getting power to gauge. What do I need to do now?
OK, good.
Please follow the test procedure on the user manual.
Ok I've done that and I'm getting boost/throttle cut at around 13 psi
Is the failsafe wired in?
Yes, I wired it in just as I described in the first post. I'm thinking it has something to do with the settings but I'm not sure.
