Old 18-07-2011, 11:10 PM
obsolete obsolete is offline
Default 08 WRX failsafe w/ HFS6 & GrimmSpeed EBCS
I'm using a GrimmSpeed 3-port EBCS and an HFS6. Would like to know the ideal way to utilize the failsafe on the HFS6.
Since this EBCS connects to factory harness and such, should I connect white and brown wires as I would with an OEM boost control?
Also, is this diagram of HFS3 wiring applicable with the HFS6 as well?
Thanks!
Old 19-07-2011, 04:10 AM
Howerton Engineering
Default Re: 08 WRX failsafe w/ HFS6 & GrimmSpeed EBCS
As for the failsafe yes, just consider the GS unit to be the same as the OE unit for hooking up the wiring.
The connector on the HFS-6 is yellow, but the red/green/brown/white are all used the same.
