Old 24-10-2010, 12:21 AM
frotou frotou is offline
Default 2D system on celica 7agte
Hi there ;
I want to share with you my long time and hard work project ; I own the car since 10 years and got it serious from 3 years now (performance part) . The engine is a 7afe block with 4age head .
The shorted mods list ;
;hks gt3037 , gt2 wastegate, bov, cam gear and timming belt ; Autronic engine management ; pauter rod with arias piston (9.8/1 CR ) ; custom intake , manifold , exhaust , piping etc ; davies craig electric water pump with controller ; electric power steering pump from renault .
the car ;
electronics boxes ;
the engine ;
intake manifold jet emplacement ; I place the intake temp sensor after the jets but I think it will be heat soaked. I'm not sure if I'll be better to change is location ?
2D system ;
on the car ;
intercooler and oil cooler mount ;
turbo and manifold ;
engine bay ;
I want to run 4x .3 jets with .4 or .5 jet after intercooler . I'm not sure also if the best location for the 5th jet is not just before the throttle body . I have to test the system and plug the dds3 options before running and tune it . Time is against me because I have to store the car for the winter in two weeks . Next year will be the one for the project.
Comments and suggestion are welcome !
Claude
Old 28-10-2010, 09:53 PM
Fish Fish is offline
Default Re: 2D system on celica 7agte
Very nice setup there... As for time is running out due to winter! Dont you have a garage out there?
If you're serious about a 5th jet, place it just after the intercooler. This will give an initial pre-cool down before the main throttle body jets.
Fish
Old 31-10-2010, 11:51 AM
rogerius rogerius is offline
how did you support all that turbo+WG+manifold weight? I could not see any supporting bracket or hanger!
Nevertheless, great setup!!!
Old 20-09-2011, 04:20 AM
There is a brace from turbo housing bolt to engine support .
I still work on the car ; I have to steal every second I spend on it.
I think I will need pulse strecher because the primming pump not work in the same time as the main pump and the line trap air quickly . I hope this is the solution.
