Hello.
I'm looking for a wmi system and this looks the best. But I still have some questions, what's the difference between hfs3 v2 and v3? I'm running on 1,4 bars in my 207 reaching 245whp. It's an 1.6 turbocharged petrol with stock injectors What size of nozzle do I need to use if I want to run on sprayer fluid? Or just water? Last edited by Rickk207; 07-04-2014 at 12:41 PM. |
The v3 replaced the v2 last March.
For 245whp, you need to run a 0.6 or 0.7mm nozzle with M50/W50. Richard
So windscreen fluid or pure water isn't a option?
I won't change the ecu settings for wmi. It's just a bit more power and safety against the carbon buildup. |
Washer fluid contains high percentage of water so the flow has to be reduced. I think a 0.6mm is more appropriate.
Oke thanks for the info.
Is there difference in washer fluid, witch to use and witch not? |
I cannot answer this question, they are all different, depending on the maker.
Are there some ingredients often found in washer fluid that would be bad for the pump/engine?
So I know witch fluid to take or not to take. |
The best way to avoid problem mix is made your own water/methanol mix. Get some colour dye from a fabric shop and colour the mix. Only use DI water.
Can you explain to me where I need to connect the ecu cabel?
It says to the injector... But how I suppose to connect that? I want to know how to connect everything before ordering a kit. Last edited by Rickk207; 09-04-2014 at 02:14 PM. |
I am unable to locate a factory ECU pinout diagram.
You need to splice the red and green wire of the green harness directly to fuel injector. There are two wires from the fuel injector. There is some here installed the system to a 207 sometime ago. I will ask him. Richard
