Old 12-04-2014, 12:18 PM
Rickk207 Rickk207 is offline
Default Re: peugeot 207
I got the power supply, ECU and Gauge inserted.
When i start the engine the gauges turn orange, after 5 sec it turns red...
What is can this be?
The emmision error is been fixed already.
I installed like the mini diagram.
ECU:
- Blue on MAP sensor
- Red on switch ignition
- White on the wastegate valve begin
- Brown on the wastegate valve end
USER:
-Green on injector -
-Red on injector +
Old 12-04-2014, 01:17 PM
I heard something about soldering some things together in the box to make it work on this engine????
Old 12-04-2014, 01:43 PM
For di enignes, you need to cut x1 link and solder link x2.5. This is on the underside of the circuit board
Old 12-04-2014, 01:45 PM
just done that, are the cable connected good?
testing now again
Old 12-04-2014, 01:52 PM
make sure it is the green harness.
Old 12-04-2014, 03:19 PM
Got the system up and running!
Now i need to find out what the best settings are for the GAIN and THRES, tips for this part?
1 little problem, when i turn off the system, the car doesnt boost anymore, any idea?
Old 12-04-2014, 07:17 PM
I would keep all trimmer to 12 pm. Just play with the "thres" trimmer.
You need to unlink DHB if you want full boost when you switch the system off. I believe the yellow led will remain on to warn you the system is not longer cooled by the WMI system.
Old 13-04-2014, 04:31 PM
Old 13-04-2014, 07:55 PM
You have been very careful, you cannot completely prevent water getting in over a long period but at least for a year or two , you are quite safe. What about putting a plastic cover over the top of the pump also?
I strongly suggest you apply more sealants in these areas:
Old 13-04-2014, 08:32 PM
Thanks for the tip.
Next weekend will do some more sealant.
