Hi,
On manual they say that pump has to be below tank. Could you tell me if this setup is good or not? Regards. |
Can the pump be rotated 180 degrees so the pump is gravity fed. Either way, it is fine if you are not to fussy.
I will rotate it, thank you!
Boukman, please take a pic. It looks to me that the fittings would hit the pump if it was rotated.
Hi,
You are right, I got fitting issues so I put pump on car floor. Thank you |
