Old 15-05-2015, 09:48 AM
parmas parmas is offline
Default STEAM or WATER Injection ?
Hello Guys,
I have been thinking long about this and I am still not convinced which infact is the best overall when used in a gasoline forced-induction engine, in Terms of :
- Fuel Economy - Which of them has the "power" to work with the least AFR at full load?
- Air Temperature Reduction - Which of them is better in heat dissipation without reducing engine air breathing?
- Pre-Ignition / Detonation prevention - Which of them is the best safety measure?
I want to keep it as simple as possible. No alcohol can be used here and we are not taking into consideration that steam might be more expensive to run.
Old 16-05-2015, 01:33 AM
Default Re: STEAM or WATER Injection ?
Water injection. Just keep it simple, it works.
Old 16-05-2015, 09:25 AM
Flr Power, I know water injection is simple than steam injection and it works. I already made the statement on the first post.
The reason for this thread is to discuss water and steam injection pros & cons.
There are articles that mention only steam injection (not all related to auto-engines). Is it maybe there is a considerable advantage over water only ?
Old 17-05-2015, 12:45 AM
maxc maxc is offline
Steam injection when done right give more power if engine is safe tune.
Past 5 years i.ve had 2 flat tappets cams wear last year power valve leak bad on cam breakin. Wash cly out.
hopefully start step by step how too steam injection thread this year.
regards mark
Old 17-05-2015, 03:49 PM
pro- use less water con -building heat exchanger pro- Aquamist systems too control flow. Which is even more critical with steam.
Old 18-05-2015, 09:20 AM
regards mark
If you have experience in steam injection, could you give us some clear information :
- What results did you get with and without steam injection
- Temperatures : Air / Engine(coolant) / EGT's
- AFR's used
- Detonation suppression
- Steam system brief explanation.. steam temps / pressure / flow / nozzles ?
- Engine technical details
Did you begin with steam injection or you have also tried water injection ?
Old 19-05-2015, 12:22 PM
- AFR's used
about 35hp. no way of checking air temps or afrs. small boiler on exhaust gravity feed by .030 jet 26 inchs water pressure 3/16 break line to intake. 351c 9.5 comp. pump gas. 30 degre timeing back too back runs no timeing changeing gtech meter.
Old 19-05-2015, 11:15 PM
Forced induction or aspirated?
Old 20-05-2015, 12:17 AM
Aspirated. 650 carb 4v single plane intake small cam 215@.050 4v valves 2v heads, header, home port job. 325hp without steam, 360 with steam @6krpm. This year same everything but better exhaust. cam 4 degree advanced instead of -4 as before.
Old 20-05-2015, 02:20 PM
You say 325bhp without steam and 360bhp with steam.....
- Are these on a dyno?
- If yes, a graph worth a million !
- When testing the steam effect..... igntion timing, cam timing, fuel etc.. all is left as it is ?
