Old 26-11-2016, 12:27 AM
Mr.202 Mr.202 is offline
Default No water level warning
Is there a way to adjust the water level sensor so that it come on when the sensor is down. Got everything else working. Just when the level is below the sensor I don't get any warning. But if I let it get to the point that air is in the like it get both led failsafe.
Old 30-11-2016, 07:07 AM
Default Re: No water level warning
short across the two wires (black and yellow) on the pump harness, it should trigger the yellow led on the gauge. If it doesn't, check for breaks.
Old 11-04-2017, 03:00 PM
I got the sensor working now, Only problem is when shifting and the car rocks, The next gear water level fail safe happens. Is there a easy way to make it less sensitive? just the float.
Old 13-04-2017, 07:50 PM
there is a difference between failsafe and water level:
- Failsafe: both leds come on.
- Low tank level: only the bottom led comes on.
Which one is yours?
