Old 26-06-2017, 12:24 PM
benstian benstian is offline
Default Old ERL pump control
Hi,
How is the old ERL pump controlled? PWM, if so what frequency and dutycycle?
Do I need a PWM relay, or is it built into the pump? (3-wires. 2 thick and 1 thin)
How much does the pump flow?
Want to experiment on variuos cars on my dyno and have an old pump lying, but have no controller. I will setup a table on the standalone ecus to control flow.
Old 26-06-2017, 10:21 PM
Default Re: Old ERL pump control
We don't make a pump speed controller.
Old 27-06-2017, 10:49 AM
Ok thanks Richard, but what is required to make this pump work? I believe the 2 thick wires are power, but what is the 3 wire for?
Old 27-06-2017, 02:53 PM
rotrex rotrex is offline
If you talk about the ERL race pump, the third wire activates the pump.
In a 2c set-up, this line is controlled by a pressure switch enabling the pump when line presure drops below its treshhold. This is a autonomous process.
The flow to the jets is controlled by a fast acting or high speed valve through pulse width modulation. This is independent of pump control.
Old 28-06-2017, 07:29 AM
Thanks rotrex
