#471
![]() Quote:
You will see when you fit a pair of mine that it will more than likely read 100+ deg C higher than this below, and not constantly creep up all the way down the straight ![]() ![]()
#472
Ruben, here is a 3mm closed probe v's an open one (for EGT application) super extended but they dont last in real world (3000km in road car).
Anyway you can see the 3mm closed version suffers from never reaching temp and delays, not to mention being very long way from reporting something near accurate end figure. This is all legacy info from decade ago put over onto the LR software to see in a nicer format. ![]() ![]() ![]() What I have made is a probe that exceeds the fine wire super extended tip, but in a fully enclosed Inconel 600 form and many factors higher response rate, and better accuracy.
#473
In the below video these are my previous suppliers own type of probes, open element but in a stupid 1/4" size, they respond ok & are tolerable for some kind of indication of temperature.
My own design is 5 times faster than these and read ~100deg C higher at peak temperature, so far more accurate. This is super important for TIT cause I know I have lost count how many times have pulled apart a turbo to see the blades in distress, when in reality the poor cunts have been seeing temps that are maybe 200 or 300 degrees higher than what is reported via sub standard understanding of how an EGT Thermocouple works, IE: as a friend of mine said rightly it reads the temp of the probe and not so much the thing its measuring !@ Video > https://www.youtube.com/watch?v=cl8i...ature=youtu.be ![]()
#474
Got a heap of them in stock as of today, but almost all sold !
#475
How much shipped?
#476
For 2 x probes to Belgium with tracked ~8 business day delivery = ***sent***
http://www.riceracing.com.au RICESP > F40 > Zonda > ZR1 Water Injection Specialist "Can't be defeated!, don't know the word!, shoulder to shoulder!, we'll fight the world!, WE CAN'T BE BEATEN!!!" Last edited by RICE RACING; 19-12-2019 at 08:49 PM. |
#477
email sent
#478
Some more 'fact v fiction' here > http://www.syvecs.com/forum/viewtopi...5&p=6712#p6712 others talk about 'testing', when we get asked it gets done within minutes
#479
I get asked for picture of the probe and details so as below:
* Inconel 600 * Motorsport 'high heat' tolerance potted strain relief (these wont break/fail at the junction where the wires are joined - unlike some) * As per video's they are accurate as can be while being durable and also allowing multi function use (any vehicle air/fluid measure) ![]() ![]()
#480
https://www.youtube.com/watch?v=_dnmzf1lD9A
^ latest video using a calibrate meter ![]() More details here > http://www.syvecs.com/forum/viewtopi...5&p=6722#p6722
