Hi ive just fitted aquamist to my MR2 and was wondering what boost level i should have the system activate at..
Currently the car is running 14psi and the water is activated at the factory set 10psi...... also.... which way do i turn the screw on the pressure switch to alter the activation point :? :? any idea's welcome :smile: |
I don't know which way you turn the screw, but I think you'll just have to test around and see what boost level for activation works best for your set-up.
You're probably in the right area right now with the trigger at 10psi. -Craig |
Cheer's mate... ill give a twiddle and see what happens
You can install an LED across the terminals of the pressure switch mate. The activation point will be obvious then.
im injecting at 4psi on a trd supercharged 1.8l
http://img.photobucket.com/albums/v3...z/DSC00512.jpg |
| Thread Tools | |
| Display Modes | |
