Old 24-09-2004, 08:54 PM
Gelf Gelf is offline
Default Some pics of my progress on Astra Coupe Turbo (56k beware)
Old 24-09-2004, 09:37 PM
this is a great install, thank you, before asking you some question, is it possible to move this to the Gallery section?
Old 25-09-2004, 12:24 AM
Sure, i've learnt a great deal from this forum, anything to contribure.
Old 25-09-2004, 07:58 AM
I can do it for you if you like.
Forumadmin
Old 25-09-2004, 11:08 AM
Yes, thanks :smile:
Old 26-09-2004, 10:20 AM
JohnA JohnA is offline
so how does it work then? (inj volumes vs boost etc...) :smile:
John
www.max-boost.co.uk
Old 26-09-2004, 11:08 AM
Hi John, just like mention, your web site along with this forum have been a great source of info on clet closely related to the zlet and WI.
This is my first experience with WI, the installation is about half way complete.
The 2d set up as with the 1s kit is boost activated, the FIA 2 module interpret the IDC and inject water at a constant ratio to the fuel. Further adjustments can be made by varing the jet size.
I decided to use two independant set ups, so as to have full control over pressure and boost activation for each jet. Ive heard a lot of people say that they have been limited with two jets and one pump.
Any advice is most welcome :smile:
Old 28-09-2004, 08:56 PM
It is certainly unusual to use two systems, mosy people will be put off by the cost.
There is an advantage using two systems, maintaining the water pressure and not tailing off at high duty cycles of the HSV - the system can be made very linear to the VE curve.
Old 28-09-2004, 11:40 PM
I wanted to do something to improve performance, i was thinking about a stainless steel exhaust with sport cat - might yield 15 bhp if i was lucky, at a cost of ?1000. Some one else would have fitted it, job done.
With WI, theres a lot more involvement, with the potential to make some serious power gains.
Thats not to say i wont be replacing the exhaust anytime soon, what with improved performance, got to get the extra gases out :smile:
That poses a question, with lower in cylinder and exhaust temps, are the exhaust gases therefore denser and back pressure reduced ?
Old 29-09-2004, 12:19 AM
There is something to be said about lowering the EGT.
If the EGT is too low, it means that you are not taking the advantage of heat within the cylinder for making power. Power needs heat - you need to run the EGT as close to 900C as possible - for cast pistons.
If your EGT is climbing towards 1000 to 1100C, you will be in danger of a meltdown - But there will be plenty of power available. You should than inject water to control the excess EGT to within 900C or 950C to 980C for Forge pistons. The heat absorbed by the water will increase the effective compression ratio without the excess heat (semi-steam engine).
These are extreme tunes but since you have two pumps and all the controls you need to make this possible. Extra exhaust capacity will help a great deal.
