What is the recommended WI jet size (cc/min) when tuning a 300whp 2.0L motor? Currently running on 785cc fuel injectors @ 65% IDC.
4x 785 x 65% = 2041cc/minute of fuel.
Based on 10-15% of water to fuel, the jet size should be between 0.5mm (225cc/m) - 0.8mm (300cc/m).
Thanks for the formula. At 150psi pump pressure, how much does a 0.5mm jet flow (cc/min)?
I'm a little confused.
When we're talking about w/f ratio, it's mass or volume?
'97 Fiat Punto GT |
Most of your technical references like the NACA reports specified by mass, usually lb water / lb fuel.
Injectors are rated on a volume/min basis if their flow is specified in cc they are rated in cc/min. American cars sometimes specify injector flow in lbs/hr. The assumed density of gasoline is usually about 6.5 lbs/gal. A U.S. gallon is defined as 231 cubic inches volume, or 3785.4118 cc. A gallon of water weighs 8.337 lb at normal temps, or 3785.4118 grams (454 grams /lb AND 454 cc/lb) Water is the standard for density, ie 1 cc = 1 gm so for practical purposes you can measure the WI flow either as mass or volume. 1 gal/hr is approximately 63 cc/min Methanol = 0.793 g/cm3 gasoline = 2950 g/gallon = .7795 gm/cc (approximately depending on the blend) Larry |
I would like to continue using this jet size and increase pump pressure to arrive at a higher flow. Is there a simple formula to compute this? |
As I understand it, the aquamist flow chart does not use a fixed pressure, but the pressure their pump will deliver in service at the flow rate of an individual jet.
On the chart the 0.5 mm at 225 cc/min is operating at about 10 bar pressure, and the 0.8 mm jet at 300 cc/min is operating at a pressure of about 7 bar. You can correct either one to another pressure very easily. The flow rate through a nozzle or orfice changes at the square root of the pressure. For example if you increase the pressure by 4 times, you will only increase the flow by 2 times. New flow = rated flow x ( sqrt ( new pressure/rated pressure)) The 0.8 jet running at 7 bar (100 psi) and 300 cc/min would flow 1.22 times the rate 100 psi flow at 150 psi, or about 367 cc/min. Larry |
Larry, thanks for your detailed info. I am using the 0.5mm Aquamist jet and a 200psi Shurflo adjustable pump. Even now, I do not know if I am really flowing 225cc at my current 140psi pump pressure setting. Oh well, I guess I need to make sure by running my pump for a minute and measure the water going to a graduated flask.
| Thread Tools | |
| Display Modes | |
