Old 09-02-2004, 05:43 PM
capkapak capkapak is offline
Default Placement of Jet in a FMIC WRX setup
Hi,
I have an Aquamist System 2d. Recently I've purchased a Motec ECU that requires the placement of an Air Temp Sensor just before the throttle body for the best effect. I'm also using a Greddy FMIC. The water jet used to be just before the throttle body, now that the Air Temp Sensor have to take its place I need advice and ideas on where to remount the water jet. I've been told by Aquamist that I can run two jets off one pump, one before the FMIC and the other before the Air Temp Sensor. Again the water jet must not be too close to the Air Temp Sensor, otherwise the Motec will get off readings. Any suggestions?
