Old 22-10-2005, 08:15 AM
JohnA JohnA is offline
Default Methanol evaporating from the mix?
I find myself having to top up the W.I. bottle even when I haven't used the car. It could be 50cc after a week of inactivity (garaged).
I'm using the stock windscreen washer bottle, and the water tube feeding the aquamist pump has a tight-fitting grommet and silicon as well.
I suspect that it's the methanol content evaporating, but it could just be my paranoia. :?
Anyone else have the same problem?
John
www.max-boost.co.uk
Old 23-10-2005, 06:02 AM
GotH2O GotH2O is offline
the reduced surface tension of water-MeOH mixture and azeotropic effects will accelerate evaporation. Get a hydrometer between the range of 0.8 to 1 S.G. (specific gravity) to see if you are loosing just methanol or methanol/water.
Old 23-10-2005, 07:20 PM
GT-2 GT-2 is offline
Hadn't thought of that, I use a Spec C boot mounted tank (12 litres) for my setup which uses a 50% water/methanol mix, haven't notived any loss but brimmed its nearer 14 litres so difficult to tell.
bob
Old 27-10-2005, 09:23 AM
Originally Posted by GotH2O
..Get a hydrometer between the range of 0.8 to 1 S.G. (specific gravity) to see if you are loosing just methanol or methanol/water.
Good idea! :smile:
John
www.max-boost.co.uk
