#111
![]() Quote:
I will put everything onto a CD fior Friday, from day1. Friday: It won't take long to plud the unit in. We need to find a place to tempaorary mount it so that you can see what is going on. I will set the unit for zero convert but you can still see the the lights flashing on and off. Richard
#112
![]() Quote:
If the unit is effective, I will make a few more prototypes. Richard
#113
Richard - I got your email. See you tomorrow.
#114
![]() Quote:
#115
![]() Quote:
yes, of course.
#116
Richard - it all seems to be functioning correctly. The WI won't come on any lower than 3.8v at the air flow meter, so I guess this is the lowest flow at which the 10psi can be gained. Lambda seems spot on too.
#117
![]() Quote:
I can't remember at what boost the WI triggers. Can you? I have a few pictures here I took a few days ago. ![]() ![]() ![]() ![]()
#118
10psi.
#119
Thanks Mike.
The MAF threshold is between 2.6V to 4.85 volts. Each click of the trreshold potentiometer is about 0.11V. 11 clicks will arrive at the WI triggering point (3.8V). If you have a moment, could you advance the threshold potentiometer by 10 clicks (not 11), if things work as intended, the yollow led will come on almost immediately after the MAF converter is enabled by the system1s WI. Things are looking good. Richard
#120
Richard - I thought the threshold was between 3 and 5v. It takes 8 clicks to get the lowest voltage the WI triggers with.
