Old 30-03-2010, 06:21 AM
I Think I can I Think I can is offline
Default fuel mileage
what does WI do for fuel mileage on diesels
Old 31-03-2010, 09:43 PM
nutron nutron is offline
Default Re: fuel mileage
Nothing the way I have it setup.
If you had a single small nossel to spray running most of the time, then you may see some improvement.
Old 05-04-2010, 07:30 PM
Mileage can only be improved on the upper region of the boosted power band with water injection. There is little or no difference at between idle to start of the boost ramp.
Old 11-01-2011, 03:36 AM
juliadesusa juliadesusa is offline
Fuel Mileage means the usage of the Fuel with the time,If the usage of the Fuel is too much in a small time then its not good.You have the small nossel for the spray then it will more effective for the usage.
printed mugs
