			hello, i have a single stage setup it comes on at 12psi. currentlly i am using a auqamist 0.8, 4mm tail nossle w/ 100psi pump. i norrmally run about 22psi wih a frontmount intercooler. i am running 660cc injectors at about 75% dc. Do you think that this nossle is the right size for this setup?
			That is the bigegst size they recommend with the pump.
	If you dont have any problems leave it the way you currently have it setup. If you want even more you can try two smaller nozzles like dual .6mm they might flow more than a single 1.0 ask Richard about this.  |
 I thought 1mm was the biggest for the 1s system. I have been using a 1mm for awhile and it works great.  |
			I am not using a auqamist pump, the pump i am using can handel it.
