Old 28-07-2013, 07:20 PM
Grant M Grant M is offline
What turbo is that and how come no ported shroud?
Old 29-07-2013, 10:53 AM
Just one of a batch I was testing a while ago, its a Borg Warner, not a bad turbo.
These are some other parts I have been working with:
Have a brand new Pectel MQ12
Top Shelf, best ECU money can buy, best Cosworth Pi Research make.
Surplus to my requirements, comes in original packaging.
Stupidly low price! $9500!!!!
Need to learn about it here you go > http://cosworth.com/products/motorsp...s/pectel-mq12/
Screen shot of my MQ12 hooked up, and the main mapping screen using caltool V3.5
Too many useless kuuunts on egay!
This ECU is complete with ALL SOFTWARE REQUIRED!!!!
Pectel Off Load Tool
Pectel ECU Monitor
Pi Caltool V3.5 & V3.4
Pi Toolbox V6.1
All valid metafiles and external customer personalities included
I have also decided to include a 20B rotary engine map and a custom RR 13B Turbo engine mapped up to 4.8bar pressure and 9600rpm, with EVERYTHING configured correctly!
It comes with a spare data Ethernet cable (no UTC con required!) and power harness for out of car configuration.
It is a ridiculously good piece of gear, and very cheap!, they retail for over $13,500US (if you can get one at that price!).
http://www.riceracing.com.au
RICESP > F40 > Zonda > ZR1
Water Injection Specialist
Old 29-07-2013, 11:11 AM
What is happening with the SP? What's the new spec?
Old 29-07-2013, 11:44 AM
Going strong, only true road going rotary left on the planet that can out run a Ferrari F40 and be driven to work each day
Spec's ?, my old specs of 10 years ago are better than any pretenders today in that trying claim they have reliable rotary turbo cars lol .................. all with the magic of water injection
Current developments are many and varied, one day if anyone comes close to making a true road car that can be validated to perform (proven on VBOX in real world) like I have engineered RICESP then I will release some of my 'less old specs' to keep them confused and trying to catch up for at least another 10 years
Old 29-07-2013, 11:51 AM
I remember you saying you were going back too a ported motor? Have you and what's your new spec turbo based on?
Old 29-07-2013, 12:13 PM
That is proprietary.
I prototyped many specific items and interim 'solutions' which validated those investigation pathways and areas of uncovered tangible development potential, some areas are on-going and others are fully implemented in the current configuration. Parallel to this are other areas of research which are being investigated for potential benefits, these will be prioritized and fitted into the remainder of my testing program for 2013. All of these are described as 'Innovative'
Old 31-07-2013, 06:50 PM
Sounds very interesting. Have you any plans to go beyond the boost levels you have already achieved? ~35psi??
Old 31-07-2013, 11:59 PM
If you have a look at the Pectel MQ12 screen shot above you will see what its been calibrated for and run too
Old 01-08-2013, 04:37 AM
ROT8WA ROT8WA is offline
Whoo hooo 66.9 psi
Go the red dragon...Aw yeah...
your gonna need a g-suit for that... either that or do a lot of kegel exercises..
Old 01-08-2013, 05:44 AM
4.8 bar/69 psi! Really, have you managed to turn the earth backwards with that kind of boost?
