Old 08-05-2014, 10:06 AM
abo097 abo097 is offline
Default 2013 VW Golf R questions
Just got my HFS-4 installed in my 2013 Golf R. Couple of questions
I am running my P/I-R for 100% boost controlled. Now, for some reason the injection only occurs when I am accelerating through the gears. IE it does not inject during a high boost 6th gear pull. I would imagine that if your engine load is high both on IDC and boost during the 6th gear pull, you should still have injection. Maybe something is set up wrong? Any help appreciated.
Im still trying to get CONFIRMED specs for my bosh injectors, but at first glance they are stated to be 1200CC injectors. Based off of the curve supplied, I am going to use 2 jets one @ 1.2mm and the other .9mm with a 60/40 mixture. Just want to confirm with the experts here if that is something worth while. Since my injectors are so big should I change the gain from 2.5 to 1.5? Also, I changed the MAP sensor to 3 bar, since my golf R reads well beyond 22psi.
Is there anything I'm missing? Much appreciated
Andy
Old 08-05-2014, 11:24 AM
Default Re: 2013 VW Golf R questions
If you want to inject based on boost only, you need to also set the system to be triggered by boost, using the MPS jumper link.
Old 08-05-2014, 12:46 PM
I would like to keep it IDC, but it seems like when I put the jumper to test IDC on the gauge, it only shows 2 bars during all load ranges. Im thinking the gain is off?
Old 11-05-2014, 05:52 PM
Did you cut the x1 and solder link the x2.5
Old 18-06-2014, 12:09 AM
Are you using the green harness? The Golf R is a TFSI engine.
