Old 27-05-2014, 05:34 PM
HYDE16 HYDE16 is offline
Default Correct Check Valve Jet Reassembly
Hello everyone, long time lurker, first time poster. I have a fast question regarding my .4mm check valve jets...
-I converted my intake manifold jets to the 90 degree push lock fittings, before re-installing them I soaked them in warm water with alcohol to clean any debris from the first tank full of water methanol. In doing so, one of the CV jets came apart completely. Can you tell me if I have the correct reassembly orientation in the attached photo? Does anyone have a picture or diagram of the correct CV jet assembly I can reference? I want to make sure I have it re-assembled correctly as my software tune relies on equal flow rates.
-Can anyone tell me how to verify what flow rate these .4mm CV jets have? Are there different options for the flow rate within a .4mm CV jet (ie 90cc, 110cc, etc)? Is there a way to rebuild the jet to change the flow (add more flow) so I don?t need to buy all new jets?
Thank you everyone!
Old 27-05-2014, 11:29 PM
Default Re: Correct Check Valve Jet Reassembly
Very nice direct port install!
Old 28-05-2014, 09:08 AM
The 0.4mm CVJ has three options:
A ...... 90cc/min
B ...... 110cc/min
C ...... 140cc/min
I believe yours is 110cc/min.(B-version)
Old 28-05-2014, 02:08 PM
Thank you very much Richard, I take the layout very seriously, as soon as I finalize my trunk setup and custom tank from Howerton Engineering I'll share my build thread on this forum with full photos. Thanks to U-20T for the amazing install job.
A ...... 90cc/min
B ...... 110cc/min
C ...... 140cc/min
Thanks Richard, I will check my CVJs to see if they have A, B or C and will email you back.
Just as a reference for all, Richard sent me the CVJ diagram which is great to have on hand. I rebuilt my one jet last night in the correct orientation. The brass spinner at the bottom of the jet (seated against the jet nozzle) was tough to get aligned so that the check valve cylinder can seat properly. Once I got that, the jet went back together and tightened up perfectly.
Old 28-05-2014, 02:57 PM
Did you use the tool that comes with the restrictor set?
Old 28-05-2014, 02:59 PM
I did not, I'll look in my parts bin for the restrictors and tool.
Old 29-05-2014, 03:23 AM
dave80 dave80 is offline
me and Hyde will have some fun updates in the near future for you.
