Old 16-07-2014, 07:45 PM
vsgts14 vsgts14 is offline
Default Re: hfs6 problems
rich, it worked! thanks, i grounded that wire coming from the solenoid (it was black), directly to the chassis.
thanks for the help!!! i was not looking forward to buying a new kit.
Old 17-07-2014, 12:13 AM
Next, pick out the brown wire from the in-coming 8-core cable, cut it from the circuit board. Now connect it to the black wire from the coil (already disconnected from the circuit board)
Let me know.
Old 23-07-2014, 03:49 PM
ok, so the brown wire will basically be crimped with the new wire i made? (brown and black from coil connected to one new ground wire).
Old 05-08-2014, 03:32 PM
The black ground wire of the FCM is unrelated.
post a picture before I get confused. Mark the wires in question with numbers.
Old 26-08-2014, 06:27 PM
here is what I got.
Old 26-08-2014, 08:21 PM
Looking at the picture, are you connecting the black wire of the coil permanently to ground?
Old 26-08-2014, 08:48 PM
correct. the small black wire coming off the coil is butt connected to a new wire and then grounded to the chassis. is this alright?
I cut the brown wire and left it until further instruction.
Old 26-08-2014, 09:21 PM
No, you will burn the coil.
Disconect the black wire from ground and connect the end to the short brown wire. from the incoming harness.
Old 27-08-2014, 04:22 AM
okie dokie, and that's all i need to do? brown wire from the main harness connected to black wire coming from the coil? and leave the other two ends blank
Old 27-08-2014, 06:54 AM
OK, here is an illustration:
