Old 09-09-2014, 03:02 PM
Meister Eder Meister Eder is offline
Default HFS4-v3 Configuration for DI-System
Hey,
I received my new HFS4-v3-System and I am going to use it for a DI-System.
I have some questions for configurating the Controller and unfortunatly I was not able to find answers in other threads.
Fuelinjection ICD detection (green cable, grey RJ45-connector):
The wiring diagram shown on page 7 of the manual seems to be for port-injection-systems, because in my opinion connecting the green cable with (-)pin of a DI-fuel injector (solenoid) might cause a damage of the controller?!
So what to do with the green cable of the grey RJ45-connector in case of a DI-System?
IDC pre-amplifier gain:
There are three options for the IDC pre-amplifier:
x1.0, x1.5 and x2.5.
x.1.0 ist for "some DI systems", x2.5 for "95% of the current DI fueling systems" (Manual, page 21).
Can you help me finding the correct configuration for my DI-system (solenoid)?
Thank you very much!
Meister Eder
Old 09-09-2014, 07:15 PM
Default Re: HFS4-v3 Configuration for DI-System
I have replied to your email.
Old 06-09-2015, 06:23 AM
Tokay444 Tokay444 is offline
Perhaps we could share the answer here, as he is not the only one setting up for direct injection.
The Seals
Old 08-09-2015, 03:15 AM
berger berger is offline
yes please share the information
Old 08-09-2015, 07:05 AM
I missed the last two posts.
For DI injected engines:
- Prescaler to x2.5
- Red and green wire of the green harness to the fuel injector.
- The red wire of the grey harness goes to a 12V source at "pre-crank" and "run" key position. The green wire is no longer used.
You can download the current user manual to all the system on the www.aquqmist-direct.com It has all the above information.
Old 09-09-2015, 02:20 AM
Thank you Richard.
The Seals
