Old 23-09-2014, 07:44 AM
SonOfAnarchy ZA SonOfAnarchy ZA is offline
Smile HFS-3 thres problem ::repaired::
Hi all I have a Aquamist system with a HFS-3 controller and its recently broke. When I turn the ignition on immediately the thres light goes on and if I go check the FAV it begins to pulse softly if I turn the car on it then pulses much "harder" even at idle doesn't matter how I adjust the thres pot. These are the following test point values when car is off and just ignition is switched on.
Test point 5 +13.8V
Test point 8 +13.3V
Test point 23 +13.8V
Test point 16 +0.61V
Test point 15 +4.97V
Test point 11 +9.07V
Test point 30 +0.81V
Anyone have any idea what the issue may be?
Old 26-09-2014, 07:46 AM
Default Re: HFS-3 thres problem
Anyone??
Old 04-10-2014, 12:10 PM
Can you check test point 20 for me?
Old 04-10-2014, 01:55 PM
Ok my controller is at work will measure on Monday thanks
Old 06-10-2014, 07:08 AM
Hi Richard point 20 measures 1.4v
Old 06-10-2014, 05:25 PM
This looks normal.
One more measurement, pin 17.
Can you take a hi-res picture of the circuit board, top and bottom. I would like to spot any obvious problems.
Old 07-10-2014, 07:31 AM
Ok so pin 17 has no voltage what so ever. The board blew on two spots as clearly show on the picture. The 310 resistor was completely burnt I replaced it with a 470 though maybe that was the issue but after getting the correct resistor there was not change in the controllers behavior. Thought maybe it was the IC that it goes to so I replaced that as well (will not give the part number over the open forum will PM you the part number I used if you need) and still have absolutely no change in the controllers behavior. The other place it burn is where you change between a positive and negative pwm input I made sure that there where no tracks off(the positive pwm track is off didn't bother repairing it as nothing will be going to that track). Please excuse the red and black cables soldered to the board its just so I can test it on my workbench. The Aquamist system is connected to my nissan 200sx running a haltech ecu with a negative signal going to the controller. Appreciate the help thus far.
Old 07-10-2014, 08:36 AM
This looks normal.
And there is the top.
Old 07-10-2014, 05:58 PM
The resistor you replace should be a 1M ohm not 470 (47ohm). Try the correct resistor value and retest.
Old 08-10-2014, 07:15 AM
I was working off this picture for the resistor value but i just put a 1M in and its working like a dream THANK YOU very much for your assistance!!!
